Author Topic: Carbon Monoxide Bath  (Read 977 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« on: April 30, 2018 - 02:18:42 PM »
I am unable to find the source of a leak in my engine compartment.  Im bathing in exhaust fumes.  Help please...  I've got a 383 with cast manifolds.
I'm thinking about draining the coolant and removing the exhaust manifolds & re-attaching them with some copper permatex... Then installing new collector gaskets.   Any other ideas?   My firewall is pretty well sealed.
The only thing I can think of is that the exhaust manifold flap on the passenger side is stuck open?  What can I do to look into that working?
Want one?  Got one! ... finally
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: Carbon Monoxide Bath
« Reply #1 on: April 30, 2018 - 03:59:12 PM »
are you sure it's exhaust.
I have an oil leak from a valve cover that hits my pipes and makes it pretty hard to deal with when driving.  Not smoke, but fumes is what I get out of it.
Just offering my opinion.
Offline wantone
« Reply #2 on: April 30, 2018 - 07:30:48 PM »
This is when I wish I had a lift lol... aye...
Offline mrwfp
« Reply #3 on: May 01, 2018 - 07:21:45 PM »
Are you sure it is coming from the engine compartment?  I had that problem once and the exhaust was being sucked into the trunk and into the car due to a bad trunk seal.
Offline wantone
« Reply #4 on: May 03, 2018 - 12:13:34 PM »
Good call - I have replaced the trunk gasket... perhaps I should silicone the tail light housing as I know there is a little daylight there.
Offline wantone
« Reply #5 on: May 09, 2018 - 10:57:20 AM »
I ended up wiring my heat riser open. Much cleaner in the car now.
