Scary thing happened need advice
Author Topic: Scary thing happened need advice  (Read 2901 times)
Offline cudasteve72
« on: June 23, 2018 - 02:05:36 PM »
So me and the little man were out cruising this morning at a stop light about an hour into the cruise we hear a loud bang.  We get pulled over drove fine, pop the hood and the battery exploded.  We get some water on the spill get the battery out and replaced in a parking lot.  What I need help with is figuring out why.  I have 2 theory’s maybe you guys know better. Over charging.  Small block, not sure if it has correct pulleys on it, my autometer volt meter is buried at 18 while cruising.  Does the voltage regulator control charge to battery could that be bad?
TIA
1972 Cuda Custom 70 clone  416 stroker 481/531 hp/
2006 Grand Cherokee SRT8 (daily)
1970 Challenger convertible 340 (Dad's)
1967 Dart gt slant six all original 40,000 miles driver but needs restoration (Brother's)
2011 Jeep Grand Cherokee (wife's)
Offline GoodysGotaCuda
Re: Scary thing happened need advice
« Reply #1 on: June 23, 2018 - 06:23:15 PM »
Voltage regulators can certainly lead to overcharging and grenading a battery.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline jhaag
« Reply #2 on: June 23, 2018 - 10:41:05 PM »
Yes and 18 volts at cruise was your first clue!
love 70 Challengers
Offline 734406pk
  • Andy
« Reply #3 on: June 24, 2018 - 02:11:57 AM »
TIA
 Hello cudasteve72! It sure sounds like you have an overcharging issue! Not uncommon with e-bodies. Yes, over voltage can cause a battery to explode... This is not good,as an over voltage may cause even your new battery to do the same, unfortunately. Do you want to diagnose this issue yourself (with c-c.com guidance) or have a repair shop handle it?
Offline 70chall440
« Reply #4 on: June 24, 2018 - 11:50:09 AM »
First, clean everything really well, might use some baking soda to neutralize the battery acid. Change out the VR and see what voltage you get. The VR controls this so dont worry too much about how fast the alternator is turning.
Current Mopar
Past Mopars
Offline cudasteve72
« Reply #5 on: June 24, 2018 - 10:55:58 PM »
Tried a new regulator today no change.  Checked all my wiring (painless) every thing seems good.  If I had the field on the alternator wired backward could this happen. Don’t think I do but alternator is my next route.
Offline 70chall440
« Reply #6 on: June 25, 2018 - 12:20:08 AM »
I am pretty sure the fields can be wired either way and I don't think that isnt causing your overcharging issue. What alternator are you using? the VR is designed to control this (hence the name, regulator). When you say you checked it, did you install a new one or a used one? Maybe you have a condition that is killing the VR and allowing the overcharge to occur.
Current Mopar
Past Mopars
Offline 73440
« Reply #7 on: June 25, 2018 - 12:23:04 AM »
Check that you have a good ground on the VR,
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 70chall440
« Reply #8 on: June 25, 2018 - 12:26:20 AM »
 :iagree: x 2
They are held in with crappy sheet metal screws that corrode and lose contact. I always change mine out with rivnuts so I can use a machine screw and I always sand the back of them and the firewall to ensure contact.
Current Mopar
Past Mopars
Offline 73440
« Reply #9 on: June 25, 2018 - 12:44:33 AM »
Yes, I would like to replace mine with the rivnuts also.
Found this info :http://bronek.org/sailing/zamindar/resources/Alternator-regulator%20troubleshooting.pdf
I have never tested using the magnetic pull before .
« Last Edit: June 25, 2018 - 01:09:42 AM by 73440 »
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 70chall440
« Reply #10 on: June 25, 2018 - 11:38:36 AM »
Interesting but I would just replace it if you think its bad. You can remove it and take it to any local auto parts store and they can test it for you.
Current Mopar
Past Mopars
Offline cudasteve72
« Reply #11 on: June 25, 2018 - 08:25:56 PM »
If I have an older style alternator do I need to run a mechanical regulator
Offline 70chall440
« Reply #12 on: June 25, 2018 - 08:41:30 PM »
What do you mean "older style"? has this set up ever worked or is this a new built/repair?
Current Mopar
Past Mopars
Offline cudasteve72
« Reply #13 on: June 25, 2018 - 09:33:29 PM »
1800 mi on fresh build here is the alternator I’m running https://goo.gl/images/S6UWJH
Offline 70chall440
« Reply #14 on: June 26, 2018 - 12:13:11 AM »
Ok so you are running a Mopar square back style alternator; you should be fine with a electronic VR. The system is pretty straight forward, the alternator produces power and the voltage regulator regulates it to an acceptable limit. That said, the alternator shouldn't be producing 18V.
Here is what I would do, I'd get a brand new alternator and a brand now VR and install them. If you dont want to do that, then get the alternator tested, if it tests out then it has to be the VR. I can tell you that I have bought defective brand new VRs more than once.
Current Mopar
Past Mopars
