Author Topic: Concours Quality Negative Battery Cables At Josh's Muscle Car Parts  (Read 1285 times)
Offline JoshsMuscleCarParts
  • Sponsor
Josh's Muscle Car Parts Specials
1970-1974 Negative Battery Cables Concours Correct $67.89 With Code PHIL At Checkout
These are Concours correct battery cables but without the Concours price tag!
After years of use, the battery cables on your car can become corroded or damaged causing you endless amounts of frustration when driving your car. These genuine Made In The USA battery cables are the perfect way to finish off your restoration or to keep your daily driven classic on the road! These cables have the correct ends just as the factory made them for a quick and easy installation.
Why are we half the price of the other guys? Because we get these directly from the manufacturer so we do not have the huge mark up that other vendors have.
1970-71 HEMI https://www.musclecarparts.cc/shop/item.aspx/1970-1971-hemi-negative-battery-cable-with-ground-wire-concours-correct/10032/
1970-72 BIG BLOCK https://www.musclecarparts.cc/shop/item.aspx/1970-1972-b-and-e-body-big-block-negative-battery-cable-concours-correct/10035/
1970-74 SMALL BLOCK https://www.musclecarparts.cc/shop/item.aspx/1970-1974-b-e-body-small-block-negative-battery-cable-concours-correct/10038/
Cuda-Challenger Forum members save with coupon code PHIL at checkout.
See these and many more parts at our website www.musclecarparts.cc
