Author Topic: instrument gauges how to  (Read 1060 times)
Offline SwissCuda
« on: August 01, 2018 - 06:51:49 AM »
Dear I want to restore my instrument gauges and I have some questions
1) all how to remove the plastic glass... I removed all the clips bit the clock regulator handle is larger thank the hole and I cannot remove the glass completely... (picture 1)
2) where do you find a replacement of the insulation foam (picture 2 and 3)
3) where do you find replacement clips (picture 4)
many thanks!!!
Offline 70chall440
Re: instrument gauges how to
« Reply #1 on: August 01, 2018 - 11:23:31 AM »
The reset/adjustment knob is held in with a very small screw (requires a small straight blade screw driver or perhaps a small hex head wrench)
You should contact some of the gauge restoration companies for the gasket and clips. The gaskets can be made relatively easy but I have no idea where you would get the clips. Just google "mopar rally instrument cluster restoration"
Current Mopar
Past Mopars
Offline JayBee
« Reply #2 on: August 07, 2018 - 09:04:03 AM »
You can see the small "barrel screw" in this picture. I've only ever seen them as a flat head (never a hex). A jewelers screwdriver goes down the center on the knob.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline SwissCuda
« Reply #3 on: August 08, 2018 - 02:27:53 PM »
Done! Thanks
