Author Topic: 8 3/4 e body question  (Read 1578 times)
Offline darkside
« on: August 02, 2018 - 02:34:11 PM »
I'm going to be looking for a 8 3/4 for my 71 barracuda  mine has the small one ,and was wondering what lenght is the e-body rear end? thanks
Offline 1 Wild R/T
Re: 8 3/4 e body question
« Reply #1 on: August 02, 2018 - 02:44:53 PM »
http://www.moparts.org/Tech/Archive/axle/16.html
Most guys prefer to use the B body axle with the Dr Diff offset hangers.... Adds an extra inch of room for tires...  And the axle is easier to find...
Offline darkside
« Reply #2 on: August 03, 2018 - 02:38:18 PM »
b body  housing ?
Offline 70chall440
« Reply #3 on: August 03, 2018 - 03:04:46 PM »
Yes
Current Mopar
Past Mopars
Offline 1 Wild R/T
« Reply #4 on: August 03, 2018 - 07:03:51 PM »
This kit....      http://www.doctordiff.com/e-body-offset-spring-hanger-shackle-kit.html      Bolts in & allows you to bolt in a axle from a Coronet/Satillite/Charger.....
Offline darkside
« Reply #5 on: August 11, 2018 - 09:45:33 AM »
Will anything else need to be changed over to make the b-body rear end work?  rear end has the same angle ?
thanks
Offline 1 Wild R/T
« Reply #6 on: August 11, 2018 - 01:06:33 PM »
thanks
You'll need the proper driveshaft, same as swapping in an E body axle... Also the correct U bolts & spring plates... Again same as swapping in an E body axle..  Pinion angle in theory is the same, but should be checked same as swapping in an E body axle..
You need a B body housing & axles, Brakes can be B, C or E or aftermarket....
