Author Topic: rallye gauge speedo/odometer  (Read 1059 times)
Offline brotow
  • There really is a Challenger in the backround
« on: August 06, 2018 - 10:37:38 AM »
I have a 70 rallye speedometer that works but the odometer does not{no change in miles), Anything particular should I look for?  It is also missing the reset knob.  Also is there a update (quartz/electronic) conversion  for the clock? (also missing that knob)
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline 70chall440
Re: rallye gauge speedo/odometer
« Reply #1 on: August 06, 2018 - 11:21:02 AM »
You probably need to get the cluster repair or restored; look at places like Red Line gauges or just google E body instrument cluster restoration and you will get a list of companies that do it.
Yes there is a conversion for the clock, but I think you need to send in the cluster to get it done.
Current Mopar
Past Mopars
Offline JayBee
« Reply #2 on: August 07, 2018 - 08:49:56 AM »
I've had mine out a few times this summer working on an odo reset issue. The pictures are from my spare '72-'74 but the mechanisms are basically the same. Here's what I found. The tension on the vertical spring is critical - too tight and it's hard to reset to zero but all the numbers increment - too loose and only the "1/10th", "ones" & "tens" advance. That spring pushes the plastic pivoting piece forward which is a must for it to work properly. If that piece is too far rearwards then not even the 1/10th will advance. My guess is your spring might be broken or missing.
The reset knobs are readily available from several vendors.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline JayBee
« Reply #3 on: August 07, 2018 - 09:58:17 AM »
Here's a link to Instrument Services. The '70-'71 rallye clocks use kit R-3035, I've done 3 of these conversions. Keep in mind that these kits are a continuous sweep second hand, they don't "tick"/increment for each second. There might be other kits around, this is the only one I'm aware of.
 https://www.clocksandgauges.com/quartz-conversion-kit.html
« Last Edit: August 07, 2018 - 08:06:14 PM by JayBee »
John
2014 Toyota Avalon
