Author Topic: How to: Back window centering clips  (Read 901 times)
Offline SwissCuda
« on: August 17, 2018 - 03:39:35 AM »
How are the back window centering clips used? Any instructional text, video or picture on how to mount the back window?
Offline jimynick
Re: How to: Back window centering clips
« Reply #1 on: August 19, 2018 - 10:08:34 PM »
"Centering clips"? Do you mean the spring steel spacing clips that hold the rear glass up off the rear window opening bottom lip? If you do, then mine were mounted near the edge of the rear glass (3-4" from the corner)on the vertical lip so that if the glass slid down on the butyl tape, they would support if in it's proper position. Hope that helps!  :cheers:
