Author Topic: What R these Plugs 4 70 Cuda  (Read 872 times)
Offline DirksCuda
« on: August 26, 2018 - 01:58:19 PM »
These 2 plugs are under the glove box right with the flasher and key buzzer They both have power to them with the key on but I don't see any where to plug them in Thanks
Offline 70chall440
Re: What R these Plugs 4 70 Cuda
« Reply #1 on: August 26, 2018 - 04:16:38 PM »
I cannot find anything that matches those wire colors exactly, the closest things I can find are the turn signal flasher and the emergency flasher. The emergency flasher shows a pink and black wire but the turn signal shows a black and brown wire. All that said, I am looking at a 70 Challenger diagram but it should be essentially the same.
Its process of elimination, if everything works you are good, if something doesn't you need to trace it out to find out why.
Current Mopar
Past Mopars
Offline JayBee
« Reply #2 on: August 27, 2018 - 09:34:38 AM »
Map light and map light switch.
John
1970 Barracuda convertible
2014 Toyota Avalon
