Author Topic: Need opinions & advice on tranny issues  (Read 1316 times)
Offline cuda_1973
« on: September 09, 2018 - 03:23:27 PM »
Hey guys,
First wanted to say thank you in advance!!
So, I took my car in to a local shop to have some front suspension work done and the day after I get my car back, I've got transmission issues.
73 Cuda (true car) with 4 speed 727...all numbers matching.
Driving down the road after driving about 10 miles and I literally lost my clutch pedal.  Specifically, I couldn't dis-engage / push the clutch pedal all the way down, so I immediately pulled over.  It has absolutely nothing to do with the engine, which started fine after I shut it off.
I had resistance when trying to get the car into any gear (with the pistol grip shifter).  So, I pumped the clutch pedal a bunch of times and then magically, it lightened up and I got the pedal back.  Put it back into 1st and drove it about 10 feet before it did it again.
Could it be missing tranny fluid or something?  I wonder if those a-holes drained my trans fluid?  Anyone else ever had these problems?
Offline 1 Wild R/T
Re: Need opinions & advice on tranny issues
« Reply #1 on: September 09, 2018 - 03:32:53 PM »
Hey guys,
Stock or custom?  Stock the clutch has linkages no fluid.......
Offline cuda_1973
« Reply #2 on: September 09, 2018 - 03:45:01 PM »
It's stock...I'm sending you a photo of the underside when I first bought the car.  If there's no fluid, what on earth would cause this then?
Offline 1 Wild R/T
« Reply #3 on: September 09, 2018 - 03:59:22 PM »
Sounds like the pressure plate or disc has failed..... I've had a number of pressure plates fail & cause similar problems... I've had one disc failure where the damper spring broke & got trapped between the pressure plate & disc cause a similar problem...
Offline cuda_1973
« Reply #4 on: September 09, 2018 - 04:33:12 PM »
I owe you a beer!  Maybe a case of beer.  I'll let my mechanic know.  Any ballpark on how much something like this should cost to repair or did you fix it yourself?
Offline 1 Wild R/T
« Reply #5 on: September 09, 2018 - 04:37:03 PM »
I always have done my own work.... To cheap & to stubborn to pay someone else...
Offline cuda_1973
« Reply #6 on: September 12, 2018 - 07:32:23 AM »
You called it.  Damper spring got stuck in between pressure plate and disk.  : ) Thanks again for the great advice!
Offline 1 Wild R/T
« Reply #7 on: September 12, 2018 - 10:46:22 AM »
Awesome! Glad you got it fixed quickly....
