Help with my gauges please.
Author Topic: Help with my gauges please.  (Read 900 times)
Offline pain995
  • My Red Hot 69.
« on: July 12, 2005 - 06:16:27 PM »
Hello all,  I'm moving onto getting the gauges in my 69 working.  They were not working at all.  So after digging I noticed that there was a wire coming from terminal A as shown in the photo.  According to the document with the photo this wire should tie onto terminal B (at least thats how I'm reading it).  So I hooked it up and started the car and the gauges all started to move.  But they all kept moving to a maximum reading.  Anyone have any advice for me as to what would cause this??  Also the silver component on the left hand side with the wire coming from it.  Any idea what that is and where that wire gets hooked to?  I'm a newb but I'm definately learning alot from you guys.  As always thanks for any help you can give me.
This IC panel shows how power flows through the three-gauge gas, oil, and temp circuit. Terminal “A” is Power In to the gas gauge voltage regulator, then to the gas gauge bi-metal bar in “B.” “B” feeds power to “D” (Power In to the temp gauge) and “F” (Power In to the oil pressure gauge). Power flows through each gauge and to the sending unit through the sending-unit terminal. “C” represents the gas-gauge sending-unit terminal. The temp gauge is “E” and the oil-pressure gauge is “G.”
Proud Owner of a 69 Barracuda
Offline Mr. 6pak2go
  • Restore it dont crush it!
Re: Help with my gauges please.
« Reply #1 on: July 12, 2005 - 07:06:20 PM »
after you hooked a to b it work but it was showing a max reading right?? sounds to me like there is to much juice goind to your gauges!! there is a empty terminal next to a connect that on and b up and see what happeneds!! im just guessin here if it dont work il try again!!  good luck!!
My family, My cars, My guns three things il fight for!!
Offline pain995
  • My Red Hot 69.
« Reply #2 on: July 14, 2005 - 06:20:58 PM »
No luck trying that I got the same results.  Also I can't seem to find a voltage regulator anywhere by the gauges.  Anyone no where it would be located on a 69 barracuda?  Also how would you go about properly grounding the gauge panel.  Sorry but I'm in the learning phase :)  Thanks again
