Author Topic: Turn signal not working on one side  (Read 1894 times)
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
« on: October 08, 2018 - 03:34:52 PM »
So I replaced the turn signal switch in the column. I was thinking the problem with the signal was that the lever would not hold on that side. So I replaced the switch and it didn't fix the problem. The Hazard flashers work just fine. Signal on the driver side works fine. But passenger side is just dead. I was thinking it was a ground issue. What are your thoughts.
Offline 70chall440
Re: Turn signal not working on one side
« Reply #1 on: October 08, 2018 - 03:59:18 PM »
If I understand you correctly, they flash with emergency flashers on? If so, it has to be something in the column or the actual turn signal and its associated wiring.
Current Mopar
Past Mopars
« Reply #2 on: October 08, 2018 - 06:49:21 PM »
Then I would think it would need to be down at the Signal because with the recent parts I haven no replaced the entire turn signal wiring in the column. I am kind of wondering if it's a ground do the signals have a ground wire or do they ground at the light? The car does seem to have grounding problems. The marker lamps don't seem to have a ground either.
Offline 70chall440
« Reply #3 on: October 08, 2018 - 09:12:57 PM »
What year/car are we discussing here? There is definitely a ground in the system, typically at the lights.
Current Mopar
Past Mopars
« Reply #4 on: October 09, 2018 - 02:28:58 PM »
Sorry man, mine is a 74 Challenger.
Thanks so much you have been really helpful.
Offline 70chall440
« Reply #5 on: October 09, 2018 - 02:46:06 PM »
You are welcome. Not to sound "preachy" but wiring isn't that hard, its just frustrating and requires a methodical approach. There is generally a start and end point and wires are either hot or ground. Just determine which wire you want to trace and develop a method of test it. Fortunately a lot of electrical test equipment is now available and cheap on places like Amazon. The best piece of equipment you can get is a Power Probe, it will make life much easier.
Current Mopar
Past Mopars
