70 cuda alternator
Author Topic: 70 cuda alternator  (Read 1396 times)
Offline Mikey340
70 cuda alternator
« on: November 15, 2018 - 10:27:19 PM »
I am looking at upgrading my alternator for more output.  I could use recommendations on bypassing the ammeter and upgrading the wiring.
Thanks
Offline 70chall440
Re: 70 cuda alternator
« Reply #1 on: November 15, 2018 - 11:12:11 PM »
Current Mopar
Past Mopars
Offline Beekeeper
« Reply #2 on: November 15, 2018 - 11:21:55 PM »
Run a 10 gauge wire directly from the large post on the back of the alternator to the large post on the solenoid where the positive battery cable is connected. You can leave the dash wiring alone. By using a thick wire like this, the majority of the current doesn’t go through the smaller wire at the firewall junction, reducing the chance of problems. You will notice the ammeter no longer does much after this but that’s no big deal.
Take a voltage reading at the battery with the car running before you add this wire and afterwards. You will see a nice improvement because the smaller factory wiring has a lot of resistance which drops voltage. Ideally, you should see voltage at the battery around 14 volts.
Offline 73440
« Reply #3 on: November 16, 2018 - 02:04:21 AM »
I added a fusible link , two wire sizes smaller ,when I did that wiring addition.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 70chall440
« Reply #4 on: November 16, 2018 - 11:22:54 AM »
Yea that is a good tip as well.
Current Mopar
Past Mopars
