Voltage regulator wiring
Author Topic: Voltage regulator wiring  (Read 2151 times)
Offline 70chall440
« on: December 06, 2018 - 09:22:01 PM »
So I have built pretty much a custom harness for my Cuda and have run into an issue with the alternator not charging. I am beginning to think that I may have wired the VR backward meaning that the one pin that goes to a field terminal on the alternator and to essentially the battery may be wired to the field only pin. I know that the alternator field connections are not specific, however I am not sure about the VR.
Anyone have any experience with this?
Current Mopar
Past Mopars
Offline 1 Wild R/T
Re: Voltage regulator wiring
« Reply #1 on: December 06, 2018 - 11:10:24 PM »
The green wire at the regulator goes from one of the two field connections at the alternator to the regulator....  The second field connection to the alternator and to the voltage regulator is a blue wire with switched 12v...
Offline 70chall440
« Reply #2 on: December 06, 2018 - 11:34:53 PM »
Thanks, I need to see how I have it wired, I am thinking I might have it backwards. The alternator isn't charging, thats for sure.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #3 on: December 07, 2018 - 06:18:41 PM »
I checked my wiring and it is correct, not sure what the issue is now. I am going to try a different alternator I think.
Current Mopar
Past Mopars
Offline 1 Wild R/T
« Reply #4 on: December 07, 2018 - 06:50:03 PM »
Unplug the regulator & temporarily ground the green wire.... If it charges think regulator... If it doesn't charge alternator is correct.... In both classes there are other possible causes but those are the common failures..
Offline AARuFAST
  • AARuFAST
« Reply #5 on: December 07, 2018 - 07:17:44 PM »
   :2cents:  happened to me. If it is fresh paint on firewall where you are mounting v regulator poor ground. Scrape paint away from holes and back of v reg. Or use a nut and bolt to mount and inside of the cowl sand the area for good ground.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline 70chall440
« Reply #6 on: December 07, 2018 - 07:26:09 PM »
Thanks I will check it
Current Mopar
Past Mopars
Offline GoodysGotaCuda
« Reply #7 on: December 07, 2018 - 07:44:18 PM »
That's what I'd do.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 70chall440
« Reply #8 on: December 07, 2018 - 10:19:47 PM »
I will definitely give that a shot, thanks all.
Current Mopar
Past Mopars
Offline 70chall440
« Reply #9 on: December 07, 2018 - 11:49:22 PM »
Alright, I tried out the grounding of the green wire. Once the key is on it has battery voltage and therefore it arcs when touching it to a ground. When the key (in my case button) is off, nothing.
Oh, and grounding the wire did not show a charge or change anything.
Thoughts?
Current Mopar
Past Mopars
Offline 1 Wild R/T
« Reply #10 on: December 08, 2018 - 03:07:10 AM »
Was the engine running?  A spark is normal...
Offline 70chall440
« Reply #11 on: December 08, 2018 - 12:22:13 PM »
Yes the engine was running.
Current Mopar
Past Mopars
Offline 1 Wild R/T
« Reply #12 on: December 08, 2018 - 12:26:08 PM »
Looks like it's time to change the Alternator....
Offline 70chall440
« Reply #13 on: December 08, 2018 - 12:37:51 PM »
That’s my plan. I really appreciate the advice. Building this car has been fun, exciting, frustrating and painful all at the same time. I grew up hotrodding Mopars but it’s a whole other experience when you change pretty much everything and now have to gain an understanding of how something works and why it works in order to make it work. This situation is a perfect example, in the past if I had a car that wasn’t charging, I’d swap out the VR and if that didn’t solve it then the alternator (and perhaps anew VR). But I would have never given any thought to the wiring because it was factory. Now everything is suspect and I have to dig deeper to understand and solve these problems (obviously with the help of guys like you). Just goes to show that no matter how much experience you have you can always learn.
Anyway, sorry for the rambling and thanks again. I am going to try a new alternator and will post the results
Current Mopar
Past Mopars
Offline 1 Wild R/T
« Reply #14 on: December 08, 2018 - 01:15:33 PM »
We've all been there, change parts & hope for the best, I've always been the guy that spent a little extra time trying to understand how it works in hopes that it'll help me next time.... Often it does but these days things keep changing & what you thought you knew doesn't match up to current technology.... Which is one of the reasons I love older cars...  I'm old, they are old.. It's a good match... :roflsmiley:  Even if I do like adding some modern parts...
