Light Package Versus Hood Pins
Author Topic: Light Package Versus Hood Pins  (Read 5185 times)
Offline Carlwalski
Re: Light Package Versus Hood Pins
« Reply #15 on: July 29, 2005 - 02:52:28 PM »
Headlight delay had nothing to do with the A01 package.  It was a seperate option.
Really? Seems odd that the light package doesn't include the light option.
What is the code for the headlight delay?  :???: :dontknow: :)
This is what is included:
Light Package (A01)
Ahstray Lamp, trunk lamp, glove box lamp, map/courtesy lamp, ignition switch lamp w/time delay, time delay instrument panel floodlight, fender mounted turn signals (N/A with R/T or 340 pkg.), buzzer, headlight-on reminder.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline RusTy/SE
  • Just havin' fun
« Reply #16 on: July 29, 2005 - 03:07:46 PM »
I believe it is L65 but will only be listed on the build sheet. Check out the 'L' row and you'll see a box reserved for 'Ignition Switch/Time Delay'...i think ::)
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline FY1 RT SE
« Reply #17 on: July 29, 2005 - 07:01:08 PM »
Light Package (A01)
L42 - $18,20 w/o A01 in 1970.
L42 - $13 w/A01 in 1970.
Offline inot2old
« Reply #18 on: July 29, 2005 - 08:16:29 PM »
Light Package (A01)
My '73 Cuda has that , but I don't think it has the ignition switch lamp.   How does that work?   Maybe my ignition switch was replaced.
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
Offline Carlwalski
« Reply #19 on: August 03, 2005 - 12:31:07 PM »
I'm pretty sure it was just a light ring around the ignition.  :???: Also wasn't A01 a 1970 only option?  :dontknow:
Here is proof from a Chrysler document about the Headlight delay for the guys that were curious.  ;)  :thumbs:
« Last Edit: August 03, 2005 - 12:32:43 PM by NZ440R/T »
Offline FY1 RT SE
« Reply #20 on: August 03, 2005 - 05:09:52 PM »
A01 was available for many years prior to and past 1970.  The way the key light was made was different depending upon the year, but basically it consisted of a set of additional wires that went up around the switch.
Alaskan_TA
« Reply #21 on: August 06, 2005 - 12:03:11 AM »
This may help, this listing is for 1970 Challenger models;
« Last Edit: August 06, 2005 - 12:05:36 AM by Alaskan_TA »
Alaskan_TA
« Reply #22 on: August 06, 2005 - 12:08:55 AM »
This listing is for 1971 Challengers;
Alaskan_TA
« Reply #23 on: August 06, 2005 - 12:14:32 AM »
This may help as well, this is from 1971 again;
Offline Robb
« Reply #24 on: August 06, 2005 - 06:24:24 PM »
My Challenger is a Sept 69 built car.
My Fender tag has BOTH   L31  and  A01 figure that one out.     ;D ;D ;D
« Last Edit: August 06, 2005 - 06:27:35 PM by Robb »
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline FY1 RT SE
« Reply #25 on: August 06, 2005 - 06:58:34 PM »
Due to the fact that A01's came with and without L31's, cars with L31 showed on the tag.
