MSD 6AL location in cuda
Author Topic: MSD 6AL location in cuda  (Read 1686 times)
Offline Cuda4u
« on: December 21, 2018 - 08:20:40 AM »
getting ready to install a fresh 512 six pack in cuda.
With MSD ignition I have been researching where to install- have read overheating issues in engine bay.
Read to install under battery box.
Thinking of passenger side compartment tucked up in front??
The MSD blaster coil —- I’ve read not to install where the factory location is on engine due to early failure due to heat.
 Appreciate any feedback. Thanks in advance
Offline Cudakiller70
Re: MSD 6AL location in cuda
« Reply #1 on: December 21, 2018 - 01:30:02 PM »
For the coil, it has to do with mounting positions depending on coil type either oil, epoxy filled or e core type coil. Best to see manufacturers install recommdations. MSD has a coil that can be mounted in stock position. Usually epoxy filled and e core coils can be mounted in any position. Where oil filled usually needs to be mounted vertical.
For the 6al I like where 1wild R/T mounted his. It’s inside just above ebrake. Looks like he made a flat aluminum mounting plate.
« Last Edit: December 21, 2018 - 01:33:54 PM by Cudakiller70 »
The above is just my opinion
John Adams
Offline Cuda4u
« Reply #2 on: December 21, 2018 - 03:06:28 PM »
It’s the anti vibration part# 8222 coil.
It is not oil cooled and can be mounted in any position. I was more curious if there was any issues with heat causing premature failures. MSD does not talk about that.
I like the idea mounting box behind e brake.
Thanks
« Reply #3 on: December 21, 2018 - 03:48:22 PM »
If stock location is up front or on side of carb, it should get some air flow and not over heat.
John Adams
