Author Topic: Interesting teardown after engine blows  (Read 654 times)
Offline cudabob496
2011 Kawasaki Z1000
Offline 1 Wild R/T
Re: Interesting teardown after engine blows
« Reply #1 on: January 05, 2019 - 08:26:39 PM »
Nice Carnage...
Offline cudabob496
« Reply #2 on: January 06, 2019 - 01:22:49 AM »
wonder what the cause was?  Maybe just squeezing 750hp out of an LS engine with
200,000 miles on it?
2011 Kawasaki Z1000
Offline jimynick
« Reply #3 on: January 06, 2019 - 10:51:56 PM »
Turbos, stupid amounts of boost and hypereutectic pistons is not a recipe for longevity and when you add in a "drive it like you stole it" mentality, $hit happens!  :nono:
Offline cudabob496
« Reply #4 on: January 07, 2019 - 12:44:19 AM »
Plus about every bolt in the reciprocating short block was probably strethched to the hilt. Would have happened sooner
I suspect, if not for LS engines having 6-bolt main caps.
2011 Kawasaki Z1000
Offline 1 Wild R/T
« Reply #5 on: January 07, 2019 - 12:37:27 PM »
I think the biggest issue was Hyperutectic pistons & ring gap...... Adding boost put enough heat in the chambers to close the ring gaps.... When the ring gap closes & the ring ends butt it sticks the ring in the bore & when the rod tries to pull the piston down the bore the ring along with the head of the piston stays near the top of the bore..... The piston skirt collapses & carnage ensues...
Offline jimynick
« Reply #6 on: January 07, 2019 - 08:43:20 PM »
Exactamundo! Check out the piston crowns with rings attached, that they were picking out of that engine! That engine was designed to run in an old Chevy truck all it's life and the engineers did NOT figure on some cowboy turboing the bejeezus out of it when they calculated ring gaps and piston longevity!  :screwy:
