Author Topic: Carb and Manifold Combo  (Read 1924 times)
Offline money pit
« on: February 02, 2019 - 05:04:30 PM »
What is the best carb and manifold combo for a 1974 360 engine. Did the 360 come with a Thermoquad as the base carb? The engine has been rebuilt and has a mild cam, otherwise stock. When I bought the engine it didn't have a manifold or carb. It's going in a 70 Barraduda with a 727 trans. Eventually I would like to get EFI. For now I just want to get it running and enjoy it. I'm looking for a daily driver not a racer. Thanks
Offline 70chall440
Re: Carb and Manifold Combo
« Reply #1 on: February 02, 2019 - 06:42:45 PM »
"best" is a relative term, there is a lot of factors that contribute to a satisfactory system; perception and tolerance being 2. The 360 would have come with Thermoquad (assuming it was a 4bbl motor). I suspect you will get a lot of opinions online as to what is "best". Everyone who has experience with these cars has a preference. I would recommend you do some research online (this counts toward that end) and see what meets your needs. For simplicity sake, you could run a factory 4bbl intake and something simple like a 600 CFM Holley (or carter, AFB, etc.). I personally like Holleys as that is what I grew up with and have the most experience with. I am not implying it is the best just what I know. That said, you could run that same 4BBL intake and a Fitech Go Street ($800 +/-) and even their new command system which eliminates the need to modify the fuel system.
Before the haters jump on my about the command center, I met with Fitech at Barrett Jackson in Scottsdale and they showed me their new system which they claim it is completely overcomes the problems with the old system.
Current Mopar
Past Mopars
Offline money pit
« Reply #2 on: February 03, 2019 - 01:20:37 PM »
What was the problem with the Fitech system and the fuel system? I did a little research and found that the Performer intake with a Edelbrock 600 cfm is a good combo for a every day driver. Like I said EFI is an option in the future.  Thanks
Offline 70chall440
« Reply #3 on: February 03, 2019 - 03:48:23 PM »
The problem was the command center, the original was problematic and had issues. Fitech redesigned it so that it can be mounted in a wider variety of configurations and enhanced the performance.
Current Mopar
Past Mopars
