Guess what I ran at my first drag strip run?
6 inches.
I think I striped all the teeth in the 8 3/4 rear end. Had to get a tow home.
I had the rev limiter set to 2500 rpm, on the street it will launch and spin the tires.
On the strip the tires didn't spin or move. NO
If I buy a racing set of gears, should it be OK? I have 3.55 ratio.
I read hear the 8 3/4 is usually strong enough. I only went to the strip to race my son and bring the grand kids to watch
Don't plan on racing it, just the strip a few time to see what it would run.
Its a 505 build for torque, dyno 500 at the rear wheels. It has a street twin clutch mated to a Viper 6 speed and Denny's nitorous ready drive shaft so the rear was the weak link.
Do you think a new gear set will be OK or go for a Dana 60?
I still have to pull it apart to see where it broke, maybe it wasn't put together correctly and teeth were not aligned properly?
Dan
