Disc Brakes
Author Topic: Disc Brakes  (Read 654 times)
Offline DirksCuda
Disc Brakes
« on: March 24, 2019 - 01:51:48 PM »
I want to put disc brakes on my 70 cuda. I bought a set of spindles an brackets off a 73 challenger. Right now im running 14 inch rallies will I be able to use these with the disc brake setup. I don't want to have to buy new tires an rims mine are new Thanks for any help Dirk
Offline 70chall440
Re: Disc Brakes
« Reply #1 on: March 24, 2019 - 02:31:47 PM »
Depends on the size of rotors generally but if you are going to run a stock setup you need to research if discs were an option with 14" wheels.
Current Mopar
Past Mopars
Offline bc3j
Disc Brakes
« Reply #2 on: March 29, 2019 - 12:12:47 PM »
Initially, I had bought disc brakes with the slider calipers and the 11” (10.87” I think) rotors. Before they were installed I was able to drop the spindle rotor assembly in my front 14” magnum wheels that were off the car and they fit. I upgrade to 15” torque thrust D 15x7 front wheels and used those 11” rotors. Later I upgrade to the 11.75” rotors, which fit the 15” wheels. The smaller disc rotors did fit my 14” wheels.
« Last Edit: March 29, 2019 - 12:17:51 PM by bc3j »
