Good day all. New guy here.
I have recently acquired a 70 RTSE and have a steering issue. As the title suggests, it steers very tight to the right but not nearly as far to the left. I have removed the steering wheel and confirmed the splines are correctly located. The pitman appears to be located correctly. Center link looks ok. joints are all new. The box is power steer. Sooooo, is it possible for the coupler to be incorrectly splined as the manual also indicates it has a master spline?
Or is it more likely I have an incorrect pitman arm? I noticed the grease fitting was removed to allow clearance past the torsion bar. 3.5 turns lock to lock but I can only get a little better than 3 and a bit as the tire hits the frame on the passenger side. Steering wheel is centered as it appears the pitman and idler arm are when straight.
Anyone experience this, or have a suggested path to diagnose? Appreciate the help thank you.
mike
