Author Topic: Road Lamps  (Read 961 times)
Offline DirksCuda
Road Lamps
« on: April 17, 2019 - 02:51:38 PM »
Im about to hook up my road lamps but run in to a problem. I got power coming to the toggle switch and power going out both wires are light green. They run up to the drivers side where agrommet pops threw the firewall. I got no power at the wire under the hood. Its hard to see under the dash but is ther another plug in up there. I got the wiring diagram but cant figure it out Thanks DirksCuda
Offline 70chall440
Re: Road Lamps
« Reply #1 on: April 18, 2019 - 11:59:39 AM »
You need to trace the wire from the switch out to the engine compartment to be sure you are dealing with the correct wire.
Current Mopar
Past Mopars
Offline 67vertman
  • Member since 9-23-2005
Re: Road Lamps
« Reply #2 on: April 18, 2019 - 11:03:35 PM »
here is a picture of the whole wiring harness for road lamps.
As you can see there is a relay and a couple of junctions.
Offline DirksCuda
Re: Road Lamps
« Reply #3 on: April 19, 2019 - 06:53:12 AM »
Thanks for the pic 67vertman. It looks like someone put the accessory and road lamp wire threw my firewall backwards. I will have to pull it back threw and have a look. Thanks again  DirksCuda
Offline JayBee
Re: Road Lamps
« Reply #4 on: April 19, 2019 - 09:30:44 AM »
Here's something else that should be helpful.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline DirksCuda
Re: Road Lamps
« Reply #5 on: April 21, 2019 - 07:06:01 AM »
Thanks JayBee got it figured out. Another question does the reverse dash light get its power from the switch on the 4 spd trans Thanks
Offline JayBee
Re: Road Lamps
« Reply #6 on: April 21, 2019 - 09:52:36 AM »
Sorry, don't know that. This is the best I can offer up.
John
2014 Toyota Avalon
Offline JayBee
Re: Road Lamps
« Reply #7 on: April 21, 2019 - 01:04:09 PM »
Found this old thread, pretty sure Cuda and Challenger would be the same...
http://www.cuda-challenger.com/cc/index.php?topic=64515.0
John
2014 Toyota Avalon
