Author Topic: 71 'Cuda 2nd fender tag  (Read 1405 times)
Offline Martin MPR
« on: April 23, 2019 - 04:47:14 PM »
In the process of restoring my 71 BS23H1B 'Cuda and getting a new fender tag made. I have the old one and just found out today there was a 2nd fender tag I do not have.....
Is there any way to find out what was on the other fender tag? I do not have the build sheet.....
Thanks in advance for your help,
Martin
Offline Fern
Re: 71 'Cuda 2nd fender tag
« Reply #1 on: April 23, 2019 - 05:02:15 PM »
Without the build sheet, it's impossible to know for sure what came with the car. If the car is original you can see which options are missing from the 1st tag.
Offline 70chall440
« Reply #2 on: April 23, 2019 - 06:54:50 PM »
What Fern said basically. Careful inspection of the car can provide clues as to what it came with but there is no way to know 100% without the tag or the sheet.
Current Mopar
Past Mopars
Offline Martin MPR
« Reply #3 on: April 23, 2019 - 08:24:19 PM »
Thanks for the replies, found a list of all possible codes and will inspect the car with the list in hand. Write down all codes not already on the 1st tag and hope they will make me a 2nd tag based on the inspection!
Verstuurd vanaf mijn SM-G960F met Tapatalk
Offline Culvers
« Reply #4 on: April 25, 2019 - 07:58:41 PM »
Show us the first tag, maybe we can say what should be on the second tag.
Offline Martin MPR
« Reply #5 on: April 25, 2019 - 10:01:51 PM »
Great; hope you guys can point me in the right direction.....
Offline Culvers
« Reply #6 on: April 26, 2019 - 06:01:42 AM »
on the second tag there could be an additional radio code (R..), maybe a stripe code (V..) and in some cases the radiator size. On some tags I've seen rare Y-codes, if the car was very special.
But without the broadcast sheet you never could make it correct.
Offline 70chall440
« Reply #7 on: April 26, 2019 - 12:27:08 PM »
I believe that the "CTD" indicates a second tag (as in "continued"); however what codes were on it remain to be seen, could have been with one or 2  codes like the radiator size and a Y code and then  "END" (for end). But as stated, without the build sheet there in no way to know for sure.
Current Mopar
Past Mopars
