Cuda grille fit issue
Author Topic: Cuda grille fit issue  (Read 645 times)
Offline 70CudaProstreet
« on: May 15, 2019 - 10:13:17 PM »
GRILLE FIT ISSUE
I may have asked this before and have forgotten so I apoligize in advance if that’s the case. I installed my 70 Cuda grille a few months back and had a question on spacers.
I used a Classic kit that had all new plastic bushings/biscuits and bolts. My question for those that know is, on the very middle mount on the top of the grille,the peak let’s call it, is there also a spacer between the grille and the top balance? The issue I’m having is that the grille is spaced perfectly around the fenders ect until you get to the top middle. At that point it’s really close with no gap. And from what I can see there’s no room for a spacer to be inserted between the grille shell and the metal tab that’s against it. So I guess I need to know how many biscuits are supposed to be used. Thanks.
70 Pro Street Cuda
76 Pro Street Plymouth Arrow
2005 Magnum R/T modded
2006 Dodge Ram 2500 4x4 CTD
