Thanks, I think it is going to be a pretty neat wagon for sure. I worked on the sending unit some more, installed the hard line adapter and went to install/attach the fuel pump. The plan was simple enough, cut off the pickup tube and then bead the tube so that the fuel line will not come off and assemble the pump to the line. The "beading" is done with a tool specifically made to do just that, the one I have is from Earls and is specific to 3/8 tubing, unfortunately I did not read the fine print for the tool because as it turns out, it is only for aluminum and perhaps mild steel (I have a SS sending unit/pickup tube). First issue is that it did not make a been high enough to secure the fuel line, secondly is that the tool was destroyed in the process (the 3 little ball bearings fell out). So, I ordered a new one ($45) and while doing so discovered its limitation, however I found another tool designed for the aircraft industry that is much more HD so I ordered that (~$200). Once I get that in I will finish the sending unit. In the mean time I am working on making the throttle body fuel delivery system.
