Author Topic: Temporary power shut off 71 Cuda  (Read 798 times)
Offline DocMel
« on: May 30, 2019 - 12:44:28 PM »
Howdy,
1971 Barracuda:
Over the last few months, just every now and then I would turn the ignition switch to start the car, and there would nothing at all from the starter, BUT all power was still on  (Dash, etc).  But after a couple of tries it would finally start, no problem.  I was thinking maybe a ignition switch going bad
The main problem just happened this weekend and just after I drove over a rough patch of dirt road.  All power just shut off and the engine died.  No power anywhere. I looked at the battery connections, no issues, got back in, and it started right up
I am thinking a loose connection somewhere:  Hit me with a list of what to check
Offline 70chall440
Re: Temporary power shut off 71 Cuda
« Reply #1 on: May 30, 2019 - 01:04:11 PM »
Start with the most obvious and work towards the less obvious;
- Battery connections (also check the alternator connections, if they were loose it would not do what you are saying, but since you are checking)
- starter relay connections
- All grounds
- bulk head connections (need to pull them off and inspect the pins)
- steering column harness connector (under the dash, comes out of the steering column)
After these, you are basically left with the ignition switch
Current Mopar
Past Mopars
