Author Topic: Help?????? im not sure if this is the right place to post this  (Read 1982 times)
Offline JRoss22
  • Member Since 05/08/2005
Ok so I pulled my car out of the garage to take some pictures. I let it sit out in the heat for a little bit not sure if this is what caused my problem but when i went back out and started it up I had a bunch of liquid not sure if it was coolant or not but it came out from under the dash in a few places I dont know what caused it at all and I hope this doesnt set me back from getting the car on the road next week. So if anyone could help me find out what was the problem that caused that it would be greatly appreciated.
Re: Help?????? im not sure if this is the right place to post this
« Reply #1 on: July 14, 2005 - 05:21:34 PM »
Your heater core just went to heaven.  :laughing:  Either replace it, or you can bypass the heater core with your coolant lines. It depends on if you want a heater or not.
Offline JRoss22
« Reply #2 on: July 14, 2005 - 05:46:54 PM »
Well since I most likely will not be driving this car during the winter at all im not going to need a heater but a/c on the other will be needed with this 107 degree weather we are getting where i live. But so how would i go aboiut bypassing the heater core?
Offline 4drbrnko
« Reply #3 on: July 14, 2005 - 07:49:32 PM »
Was it straight water, or did it smell like anti freeze?(please tell me you don't run straight water in the radiator)
If you have a/c and it is in working order it may have been condensation from it, depends on how long it ran before you shut it off and left it and how much water came out from under the dash.
<-------<<<  Clickylinks..... My vehicles
Offline BlueStreak_Johnnie
  • Y helo thar from Sunny South TX
« Reply #4 on: July 14, 2005 - 07:50:15 PM »
Two water lines, 1 in, 1 out. run the sending back into the return.
J.
Offline JRoss22
« Reply #5 on: July 14, 2005 - 09:33:13 PM »
it was deff. not straight water so it was probally anti-freeze kinda smelled funky and i can tell you it wasnt a/c condenstation bc the a/c works plus i only had the car on for the few seconds it took to pull it out of the garage and the few secs to pull it back in when i was done
Offline GoodysGotaCuda
« Reply #6 on: July 14, 2005 - 10:16:13 PM »
How about make it simpler...did it come from the passenger side? If so (likely) its the heater core. You can A) Replace it and have a heater or B) Block it off, you can drive it, no heater
-Goody
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline JRoss22
« Reply #7 on: July 14, 2005 - 10:52:58 PM »
It was more on the drivers side coming out of this little vent thing under the steering wheel and then it also came from right under the stereo but i was looking on yearone to find a new heater core and they only had one that would fit my car if i didnt have a/c so i dont know what to do about that.
Offline 4drbrnko
« Reply #8 on: July 14, 2005 - 11:29:25 PM »
Heater core will useually just leak down on the passenger side under the glovebox, I'm stumped.(doesn't take much)
If you find a good radiator shop they should be able to repair the old core, or make a new one to fit. There was a shop in 'Vegas that did one for my truck when it was in for a new Rad., came out nice. Sorry I'm not more help.
Offline KelllysCuda
« Reply #9 on: July 14, 2005 - 11:32:00 PM »
:laughup:...should be an easy fix :beer:
Kelly
Offline JRoss22
« Reply #10 on: July 15, 2005 - 12:19:07 AM »
I guess im going to have to take my car into the shop now good thing theres a local guy i trust hes done work on other cars that my family has had really good work not much he can screw up paintjob wise on my car  :laughing: but hopefully it doesnt cost to much i dont have the best paying job in the world i barely make above minnimum wage cant wait 4 more omnths and i will be working for Dodge as a lot boy get to drive all there cars.
