I had similar problems in my Challenger, ended up having to drop the valve body and found it to be gummed up and the spring for the 2-3 shift was a bit corroded. If the car sits a lot, this can be an issue. If this problem just materialized, then it is most likely not the line pressure (kickdown), its internal I believe.
