Author Topic: Sound Deading Doors  (Read 924 times)
Offline money pit
Sound Deading Doors
« on: October 10, 2019 - 11:25:36 AM »
Where should sound deadening material such as Dynamate be placed on the doors? I've seen it on the inside on the doors and on the outside of the doors (under the interior door panels). I was thinking about using Lizard skin. Has anyone had experience with Lizard skin?  Will Lizard skin deaden more sound? Thanks
Offline 70chall440
Re: Sound Deading Doors
« Reply #1 on: October 10, 2019 - 09:57:48 PM »
I used hushmat on both my challenger and cuda; I put a little on the inside of the outer panel (door skin) and I put it on the inside panel (part under the actual inner door panel). I tried not to cover anything that I would need to get to, adjustment screws/bolts and holes. There is no format really for doing this and to be honest it doesn't take a lot to work.
Current Mopar
Past Mopars
Offline Aracer
« Reply #2 on: December 31, 2019 - 12:06:30 AM »
The wind noise is subdued by a thick plastic sheet, sealer held.
It deteriorates and tears when you remove it for door lock servicing.
 And factory applied undercoating type tar sheets 3/16 thick panels on the door skin.
Without the plastic it's got wind noise at the windows. I used the thick black constriction material normally used under the concrete house slab between the gravel as a moisture barrier. I suppose you could use a stick on mat in addition to the factory noise deadener. The floor is an area not covered from the factory. There, carpet padding will work with out adding a flammable rubber product. Exhaust is noisy, and headers need fiberglass wrapping at the head.
Offline 70chall440
« Reply #3 on: December 31, 2019 - 12:55:09 AM »
Sound deadener on the doors really gives them a solid sound/feel, I also replace teh plastic with new plastic (like the stuff you get at home depot, I think 5 mil thick) and use butyl to put in in pretty much like the factory did.
Current Mopar
Past Mopars
