Author Topic: Removing instrument cluster  (Read 4314 times)
Offline BruteForce
  • '72 Dodge Challenger 340 5spd
« on: November 01, 2019 - 05:26:48 AM »
Is it possible to remove the instrument cluster without removing the steering column and the dash?
I was driving down the freeway, and noticed the speedo needle was vibrating harshly and was just a blur, and broke off. I suspect the speedo cable probably needed lube. But I need to take the speedo out to repair the needle.
Offline 4Cruizn
  • HEMI FISH
Re: Removing instrument cluster
« Reply #1 on: November 01, 2019 - 10:55:19 AM »
Yes . . start with removing the light bar that shines on the gauges, then undo the bracket that holds the steering column in its spot so that it drops down some.  Once those two things are completed, most of the screws that hold the cluster in will be visible.  The lower trim on the dash can be tricky as well as some of the screws are difficult to get at with the dash still in the car but not impossible.
Offline BruteForce
« Reply #2 on: November 01, 2019 - 07:58:24 PM »
Thank you!
Offline 70chall440
« Reply #3 on: November 03, 2019 - 12:18:29 AM »
Have done it many times, make sure you remove the switch panel first. It also helps to pull the drivers seat so that the steering column can pivot down and out of the way.
Current Mopar
Past Mopars
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
« Reply #4 on: January 26, 2020 - 10:20:52 AM »
Further to the steering column hitting the seat ...... you can remove the steering wheel by removing the horn cap and unscrewing the three nuts that hold on the steering wheel to avoid removing the seat.
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
