Author Topic: Gas Rehab  (Read 1089 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Gas Rehab
« on: July 15, 2005 - 10:09:27 AM »
Just getting ready to oder my fuel rehab parts. Does anyone have a list of all the seals,parts and gaskets I will need? I will be using the Por-15 tank kit. Should I replace all parts or just rebuild and refurbish? The car has sat idle for about 20 years
[attachment deleted by admin]
SOLD
Offline VPOINTCUDA
  • Wish she were done so I could take her out Ridin!
Re: Gas Rehab
« Reply #1 on: July 15, 2005 - 08:59:45 PM »
I don't have a list , but D-mn , that looks identacle to what mine looked like when I het her home ! ! !
" the question isn't  when is he going to stop, but whose gonna stop him!"
Re: Gas Rehab
« Reply #2 on: July 18, 2005 - 02:22:32 PM »
Bump
anybody?
SOLD
Offline RusTy/SE
  • Just havin' fun
Re: Gas Rehab
« Reply #3 on: July 18, 2005 - 08:42:39 PM »
1)  Replace the fuel sending unit.
2)  Replace the sending unit retainer seal. You should be ok to reuse the metal retainer itself.
3)  Replace the filler neck to gas tank grommet.
4)  Replace the filler neck to trunk floor seal.
5)  Replace fuel pump, any non metal fuel line.
6)  Rebuild carb(s).
Basically anything non metal has lost it's 'integrity' after 20 years. 'Wag', my 73, had an unknown history when bought in '03. When water was found in the gas, i dropped the tank and discovered jb-weld on top of the tank had deteriorated and was letting moisture in. I replaced every component from the fuel system except the filler neck. Overkill? Yes but i won't have fuel system issues any time soon.
Russ
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Re: Gas Rehab
« Reply #4 on: July 18, 2005 - 08:49:14 PM »
Thanks Rusty
SOLD
Offline RusTy/SE
  • Just havin' fun
Re: Gas Rehab
« Reply #5 on: July 18, 2005 - 10:21:28 PM »
You're welcome :thumbs:
Russ
2001 Durango     1B4HS
