Author Topic: Wind Noise From Drivers Window  (Read 2346 times)
Offline money pit
Re: Wind Noise From Drivers Window
« Reply #15 on: March 07, 2020 - 12:23:46 AM »
I have another problem related to the door window. The window gets loose all the time. I had to take the window out twice to tighten the front plastic guide that attaches to the window. It seems like it's a bad design. When you tighten the screw the end of the plastic guide mushrooms and tightens against the glass.  The hardware is new. I was thinking of replacing the screw with a bolt and use a nylon lock nut.Any suggestions?  Thanks
Offline 70chall440
« Reply #16 on: March 07, 2020 - 03:37:13 PM »
 If the screw is coming loose, I suppose you could replace it with a bolt but I would be wondering why it is coming loose as that is not normal.
Current Mopar
Past Mopars
