Author Topic: MP brake booster and Wilwoods  (Read 1451 times)
Offline Chlngrcrzy
« on: May 13, 2020 - 09:54:06 PM »
I am converting my non power brake challenger to power brakes, looking to use the MP Brake booster kit for that. I also want to put Wilwood brakes on the car. The back are the old drums, and the fronts disc. The car is dangerous as it is, and requires a tremendous amount of leg and brake pedal power to stop.
Is there any particular business that I should use for ordering the Wilwoods? Not sure if the price differs with different stores or not. I would like to spend my money with a business that could really use it right now.
Offline 70chall440
Re: MP brake booster and Wilwoods
« Reply #1 on: May 13, 2020 - 11:31:29 PM »
For brakes your best source is Dr. Diff, however I am not sure if he sells Wilwood products. Note that Wilwood calipers are not all that good on the street if that is what you are thinking. While 4 wheel discs are a given these days, to be very honest good drum brakes (especially with discs up front) are fully adequate. There is at least one company out there that makes performance shoes for drum brakes as well. If you run good pads up front and good shoes in the back with a booster, it is going to stop pretty much as good as it is going to unless you go to bigger brakes and get good tires.
Everything is a trade off and many people have swapped to 4 wheel discs to find that they don't stop all that much better that before. Likewise, many people have rebuilt the stock brakes and used good parts and found out that there car stops way better. I understand wanting the booster as most people today are not used to non-boosted brakes, me included. I built my Cuda and didn't install a booster, it has 12" front rotors with Viper 4 piston calipers in the front and 11" rotors with Cobra calipers in the rear. It stops fine but the first time I hit them I was very concerned with the amount of effort it took but then realized I didn't have a booster, once I got used to it it was fine.
Current Mopar
Past Mopars
Offline Chris Pauluk
  • New to the E game
« Reply #2 on: July 29, 2020 - 01:00:30 AM »
Dr Diff sells Wilwood stuff, direct fit bolt on and go/stop..
Chris Pauluk
Eagan Minnesota
1973 Plymouth Cuda 340 4spd (70 AAR clone'ish) bought it that way..
