Author Topic: Red Top Batteries  (Read 1408 times)
Offline Mopar_Mudder
  • I'm a llama!
Red Top Batteries
« on: May 25, 2020 - 06:08:39 PM »
I have a Red Top in my 71 Cuda. But for the last couple of years it has been boiling the acid out of 3 cells making a huge mess. Is their a good SEALED red top out their to get?
1971 Hemi Cuda
2005 SRT-10 Regular Cab Flame Red.   12.771 @ 109.67 <-----Time Slip --Video
Mopar: Headers, Exhaust, Ram Air, ECM
2008 3500 Mega Cab Dually, Resistal Edition
Offline 70chall440
Re: Red Top Batteries
« Reply #1 on: May 26, 2020 - 12:11:48 AM »
Red top as in Optima? If you are boiling acid out if it, then the cells are shorted and it is trash. I run some red top and a few yellow tops. That said, you need a good charger, specifically the optima charger. Yes I know it isn't cheap but if you have an optima battery it is worth it.
There are many other sealed batteries out there such as Odyssey, Exide, XS. etc.
Current Mopar
Past Mopars
  • I'm a llama!
« Reply #2 on: May 26, 2020 - 05:25:09 PM »
 No a red top as in reproduction of the old Mopar battery. Don't even get me started on Optima batteries, never been impressed.
1971 Hemi Cuda
  • I'm a llama!
« Reply #3 on: May 26, 2020 - 05:37:54 PM »
Well I did a little checking and I bought the battery from Summing, part #ANP-S27MRL. Description says it is Turbostart brand and says it is a sealed battery. When it definitely is not seals, the caps screw on and each cap has a vent hole in it. I checked to make sure the caps vents are functional and they definitely are, as you can tell by the puddle of battery acid on the floor!
1971 Hemi Cuda
Offline 70chall440
« Reply #4 on: May 26, 2020 - 11:03:34 PM »
Well first off I have and use probably 7 or 8 Optimas, I have read many comments by many people against them but I have at least one that is probably 13 years old, so I cannot complain.
As to your "turbo start", I am still thinking it has to do with your charger.
Current Mopar
Past Mopars
  • I'm a llama!
« Reply #5 on: May 27, 2020 - 09:02:21 AM »
Funny this is this all started when I got to a show one day opened the hood and their was acid coming out of one of the caps on the battery. Wasn't from charging or a battery tender, checked to output of the alternator and that seemed fine. So I checked the level in the battery and they were all low so I added distilled water. Well I did some reading last night and these are AGM batteries and listed as sealed but they are not what I would consider sealed. Now I am questioning if I should have added any water to it or if it is suppose to be dry being AGM. I have an e-mail in to Turbostart to see what they say.
1971 Hemi Cuda
Offline 70chall440
« Reply #6 on: May 27, 2020 - 02:14:17 PM »
Yeah I don't think you are supposed to add anything to a gel battery.
Current Mopar
Past Mopars
