Author Topic: Died and will not start  (Read 971 times)
Offline brotow
  • There really is a Challenger in the backround
« on: August 29, 2020 - 12:58:54 PM »
My 1970 Challenger with I believe 1971 rallye gauges dash has been running fine, but lately engine had trouble with higher rpms. Now it wouldn't restart after getting gas, It will start and run until I release the key from the start position to the run position and dies.  I replaced the ignition switch, didn't solve the problem. I remember before replacing the ignition switch the coil showed low voltage to it.  I'm running a stock electronic distributor. Does 1971 dash have a seat belt interlock system? I'm at a loss, any suggestions?
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline dodgedream
Re: Died and will not start
« Reply #1 on: August 30, 2020 - 08:59:54 PM »
Sounds like your ballast resistor has given up.fast fix and I would recommend carrying a spare as they are known to fail
Offline JayBee
« Reply #2 on: August 31, 2020 - 09:37:52 AM »
I second the vote for ballast resistor.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline brotow
« Reply #3 on: October 09, 2020 - 05:28:42 PM »
Switched out the ballast with a new one, (resistance measured the same). Bought a new ignition control box, no change (MOPAR HR7500 Electronic Ignition Module).  https://www.ebay.com/itm/324317385004
« Last Edit: October 09, 2020 - 05:34:36 PM by brotow »
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #4 on: October 09, 2020 - 09:38:00 PM »
seatbelt interlock system started in 74.
Offline jimynick
« Reply #5 on: October 09, 2020 - 10:28:30 PM »
I'm not a big electronics guy, but I seem to remember that the coil is supplied a full 12 volts in start position and that it then goes down to about 8 volts if I remember. I'd be looking at a schematic to determine the colour of the run wire- for some reason I want to say it's brown- and check for connectivity at the firewall bulkhead connector- a notorious source of wiring failures and problems. Just my  :2cents:
Offline brotow
« Reply #6 on: October 10, 2020 - 04:20:27 PM »
Yep. that would be my next step.
Offline brotow
« Reply #7 on: October 11, 2020 - 08:28:47 PM »
My thanks to  jimynick.  Loose? connection in the bulk head connector. never found the reason, it's up and running' moving the wire around did not make it stall out.
Offline jimynick
« Reply #8 on: October 11, 2020 - 11:03:17 PM »
Good to hear you got it!  :thumbsup:
Offline 70chall440
« Reply #9 on: October 20, 2020 - 01:00:45 AM »
Check the steering column connector as well, I had a very similar issue. I realize you got it sorted out but check the connector just be sure.
Current Mopar
Past Mopars
