Turn signal resets my radio
Author Topic: Turn signal resets my radio  (Read 633 times)
Offline Chlngrcrzy
« on: September 25, 2020 - 09:58:35 PM »
I have an aftermarket radio that turns off and switches back to its set up menu whenever I use the turn signal. What the he..!  Is this a ground issue and if it is, what needs to be grounded?
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: Turn signal resets my radio
« Reply #1 on: September 26, 2020 - 10:27:42 PM »
That's quite the wiring mix up.  I'm curious to know what you find out.
Offline Chlngrcrzy
« Reply #2 on: September 27, 2020 - 08:48:52 AM »
Whats crazy about it is that I have it wired into the spare wire that comes from the fuse block that is used for auxiliary purposes. I believe it is the orange or yellow.    :clueless:
Offline JayBee
« Reply #3 on: September 27, 2020 - 04:10:50 PM »
Why didn't you just get power off the red wire from the original radio's plug?
Orange is typically used for lighting, yellow might be lighting too.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Chlngrcrzy
« Reply #4 on: September 28, 2020 - 09:20:08 PM »
I will have to look, it may be the red. I don’t remember, but when I tested it for power it was hot all the time, and that was the wire I needed for the continual power for memory. The Radio power comes from the original wire for the old radio.
