Author Topic: Looking for a mopar tuff wheel adapter  (Read 1252 times)
Offline brotow
  • There really is a Challenger in the backround
« on: November 20, 2020 - 09:09:51 AM »
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline 70chall440
Re: Looking for a mopar tuff wheel adapter
« Reply #1 on: November 20, 2020 - 03:17:06 PM »
For what? Most tuff wheels will bolt directly to an E body crush can.
Current Mopar
Past Mopars
Offline brotow
« Reply #2 on: November 24, 2020 - 11:22:53 AM »
I like to find a tuff wheel " crush can". I have the wheel.  If I use the regular crush can the wheel will be way too close.  I always felt the regular wheels and crush can, the wheel is still to close to the driver. I was thinking of cutting down a crush can to bring the wheel further away, and maybe using a b body directional rod which is straighter(less angle). I know the set up with the tuff wheel and the shorted crush can will bring it at more or less the same distance.
Offline 70chall440
« Reply #3 on: November 24, 2020 - 12:00:53 PM »
Ok so what you are looking for is something to put the steering wheel closer to the dash? There is only one crush can for an E body and while you can cut it and shorten it, you can only go so much because the wheel will be too close to the dash. You might think about moving the seat instead.
Current Mopar
Past Mopars
Offline brotow
« Reply #4 on: November 27, 2020 - 05:21:59 PM »
I could move the seat back then I'll need to put blocks on the pedal.   My massive height of 5'6" don't help much
Offline 70chall440
« Reply #5 on: November 28, 2020 - 12:03:19 AM »
So you are actually trying to get father forward? I think cutting and shortening the crush can is your answer.
Current Mopar
Past Mopars
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
« Reply #6 on: February 13, 2021 - 10:49:00 PM »
Tuff Wheel, Rim Blow Wheel adapter Part Number 3467186 ~3"
Will put the turn signal lever in the correct orientation too compared to the standard E-Body Steering Wheel Crush Can ~4-3/4"
There are reproduction but I didn't see any in stock with a quick Google search.
But not all crush cans were created equal.
From another thread here... http://www.cuda-challenger.com/cc/index.php?topic=99960.0
Good luck.
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
