Author Topic: Collapsed steering shaft  (Read 995 times)
Offline Plum70Dodge
« on: March 02, 2021 - 01:36:22 AM »
So, from what I gather, the inner shaft has a slot where some type of nylon material was melted into place to secure the outer shaft with 4 small pins. Why couldn't I simply warm up the shaft with a propane torch until the plastic reanimates into a bubbly goo and rewelds the pins to the center.
Im willing to listen.
South Bend
South Bend, Indiana
Offline 70chall440
Re: Collapsed steering shaft
« Reply #1 on: March 02, 2021 - 07:13:50 PM »
What is it you are trying to do?
Current Mopar
Past Mopars
Offline Plum70Dodge
« Reply #2 on: March 03, 2021 - 08:25:59 PM »
As I disassembled my steering column. I found that the steering shaft has been collapsed. That is the two small plastic shear pins have sheared.
From what I understand from Cody the center shaft has some type of groove that is filled with plastic and what looks like the pins are essentially  the spots where the melted plastic was injected.  Can you simply remelt that same plastic?
South Bend, Indiana
Offline 70chall440
« Reply #3 on: March 04, 2021 - 12:40:06 AM »
I am not sure but I'd try it.
Current Mopar
Past Mopars
