2 questions.......
Author Topic: 2 questions.......  (Read 720 times)
Offline gomangoRT/SE
2 questions.......
« on: July 16, 2005 - 07:13:42 PM »
Got a couple of things that I want to clear up..............first I am knee deep in harmonic balancers........Do the 383s and 440s share the same harmonic balancer?    Gonna have my rotating assembly balanced and I am sure he will need the harmonic balancer........
2.  My car is ps, pb, and A/C       again I have some pulleys that I inherited when i got the car.......Questin is simply this.......Does the crank pulley have 2 or 3 grooves?     How many grooves will the fan pulley have?
I am hoping crank is 2 grooves........I think fan is single groove, but not sure......thanks  Kevin
Re: 2 questions.......
« Reply #1 on: July 16, 2005 - 11:45:22 PM »
383  & 440 steel crank engines use the same dampers , 440 cast crank dampers are different & are thicker
2 groove crank pulleys are used for alt /waterpump & power steering , most A/C pumps use 2 belts so the crank pulley is a 4 groove piece
Offline Robb
« Reply #2 on: July 17, 2005 - 05:33:09 PM »
My SE is  A/C and PS
A/C compressor is 2 belts
PS is one belt
Water pump is one belt
Alternator is 2 belts
Crank is 4 belts
Idler pulley is one belt
Waterpump is one belt
Now that youre on the search for a 4 belt crank pulley......
The 4 groove pulley for a CAST Crank and the 4 groove pulley for a FORGED crank have DIFFERENT BOLT PATTERNS.   so watch for that.
440source.com has the part numbers and the detail you need to distiguish both.  eBay ought to have something for you.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
