Have a 71 challenger and the plastic pins in the steering shaft must be broke as the shaft will slide up and down in the car. I am wanting to replace the ignition switch and turn signal without pulling the column. It already has a new joint on the other end and new bearing at the base so I just need to replace wiring. What is the down side to having broken plastic pins. It collapses. Is there more slop in the steering?
