When I got my cuda at 14 the only thing I could afford was a craftsman 1.5 hp 12 gallon oil-less compressor. I still have and use that compressor 13 years later. It has powered air ratchets, impact wrenches, framing, roofing, and finish nailers. paint guns and numerous other tools. I agree with them being loud, and it doesn't run the tools as efficiently as they should be run. But, It doesn't take up much space in my little garage, and it's very portable which is a plus when I'm installing crown moulding or shingling a roof. For automotive use I'd say the minimum requirement for most tools would be 4.0 cfm at 90psi. The sanders will obviously use alot more air than that though as would a sand blaster.
