OK, so with Dave Hughes' help I decided on his high compression stroker kit. He says that with the CNC porting and combustion chamber work he is going to do to the Edelbrock RPM aluminum heads I just sent him we should be at about 11:1 for compression ratio, and with a mild cam will probably be in the 525 HP range. As mentioned previously I plan on putting the Holley Sniper EFI on this car, and I actually have a Holley Strip Dominator manifold laying around and wondering if that will do, or should I get the Super Victor?? They "look" very similar?...
