Turn signal speed
Author Topic: Turn signal speed  (Read 885 times)
Offline drswiger
Turn signal speed
« on: January 14, 2022 - 04:20:53 PM »
Ok, I suck at electrical issues so help me please. 74 challenger replaced bulbs and flasher relay because right turn signal not flashing but left ok. Well, both now glad but when I turn on the headlights, the left signal flasher slows down quite a bit. Almost to the point where you are wondering if it is going to flash, but does
Do I have a current draw somewhere or bad headlight switch? Or what
Instrument cluster dimmer doesn’t work but I am assuming that is a separate issue
Any help would be appreciated
Offline 70chall440
Re: Turn signal speed
« Reply #1 on: January 14, 2022 - 09:17:18 PM »
Most likely a bad ground.
Current Mopar
Past Mopars
