??what's the diff??or posi??
Author Topic: ??what's the diff??or posi??  (Read 1062 times)
Offline cudapurp
« on: July 17, 2005 - 01:28:01 AM »
 :stomp: can anyone tell me what kind of rear end this is   :dontknow: or if it even belongs in the back of a bh23g3b car :madvibe: i dont know  i heard that it is a  :drool: ::) posi  :drool: of some sort how can one tell?? ::)
« Last Edit: July 17, 2005 - 02:29:49 AM by Chryco Psycho »
Offline Carlwalski
Re: ??what's the diff??or posi??
« Reply #1 on: July 17, 2005 - 02:30:09 AM »
8-3/4"? (Or a 8-1/4")  :dontknow:
Confirmation anyone?  :)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #2 on: July 17, 2005 - 02:31:22 AM »
if you jack up the rear of the car & turn 1 wheel & the opposite wheel turns the same way it is a sure grip[posi ] diff , if the whell on the other side turns the opposite way it is an open diff
 not sure what diff that is
« Last Edit: July 17, 2005 - 09:56:53 AM by Chryco Psycho »
Offline Carlwalski
« Reply #3 on: July 17, 2005 - 02:35:10 AM »
If you jack up the rear of the car & turn 1 wheel & the opposite wheel turns the same way it is a sure grip [posi ] diff.
Awesome! Thanks Chryco, Great tip. I never knew that.....have to try it the next time I'm around.  :thumbs:
Offline A110235
  • '71 Challenger JH23G1B
« Reply #4 on: July 17, 2005 - 12:22:51 PM »
I don't mean to cut in on the thread, but what kind of dif do I have?  In the pic below the numbers from the drivers side of the dif appear to be 2070741.  Do they mean any thing?
Nashville, TN         Member since October 09, 2004
« Reply #5 on: July 17, 2005 - 11:39:50 PM »
the 741 is the 8 3/4 diff carrier that was the weakest at 1 3/8" pinion diameter
Offline A110235
« Reply #6 on: July 18, 2005 - 09:45:02 PM »
That sucks that I got the weak version.  Oh well.  I figured that I had a 7 1/4" dif, so knowing that it's a 8 3/4" makes me happy.  I'll try my best to break that pansy 741!
« Reply #7 on: July 19, 2005 - 12:57:09 AM »
the "weak " 8 3/4 diff will be a lot tougher than the 7 1/4
