Author Topic: Clutch Pedal  (Read 2164 times)
Offline DirksCuda
Clutch Pedal
« on: June 09, 2023 - 10:51:21 AM »
I just put a new clutch an pressure plate in my 70 Cuda. The pedal only comes half way upnow ,it dont slip or anything works just fine but why the difference. The new plate was a different style would that have anything to do with it thanks
Offline Finoke
Re: Clutch Pedal
« Reply #1 on: June 18, 2023 - 07:13:39 AM »
If you converted to a diaphragm clutch you need to remove the big over center spring that is attached to the clutch pedal
Offline DirksCuda
Re: Clutch Pedal
« Reply #2 on: June 19, 2023 - 02:24:48 PM »
Thats what i was thinking Fonoke. How do u remove that spring id it difficult to do Thanks
Offline Finoke
Re: Clutch Pedal
« Reply #3 on: June 19, 2023 - 07:05:19 PM »
The safest way is to get a stack of nickels or thick washers. Take a flat head screw driver and spread one row on the spring. Insert a washer. Do the same front and back of every spring coil. That will spread the spring enough to un hook it,
Offline DirksCuda
Re: Clutch Pedal
« Reply #4 on: June 23, 2023 - 05:45:01 PM »
Thanks for the help i will give it a go on the weekend
