WAP?
Author Topic: WAP?  (Read 746 times)
Offline miketyler
    • www.miketyler.net
WAP?
« on: July 17, 2005 - 07:31:22 PM »
Wireless Access Protocol? Well yes but what does it mean if its stamped on your crankshaft? I know R20 and M20 mean the crankshaft rod and main journals are ground down .020". What does WAP mean? Also noticed that I have letters stamped on the oil pan rails between the oil pan bolt holes. Most are stamped "B". Any idea what thats all about?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Re: WAP?
« Reply #1 on: July 17, 2005 - 11:43:28 PM »
Wap would be the initials of the company that machined you block / crank
 the letters along the pan rails were put there by the factory so the assembler would know exactly what size piston that bore needed , a might be the smaller piston by a .001 & the higher the letter the lager the piston by maybe .0005
