Hi all, just discover that forum, great !!
Ok, I want to build a 493ci from a 440 with a six-pack set-up, stage1 906 head from Hugues engines,
stock exhaust manifold (yes stock), I want it to look stock outside
but brutal inside !! I want big torque at low rpm and power thru 5500 rpm,
the engine will be in a 70 cuda 4speed, with 3.54 reargear, or 4.10 if I use a keisler 5 speed.
The car will be a driver and want to run it on pump gas.
Compression ratio 9.5:1 max.
I would like to have at least 425(FWHP) and around 450 ft/lbs of torque.
First question : I want to go with an hydraulic roller cam in the 230-240 duration at 0.050",
Am I totaly wrong with this or a non roller is just enought ? I want the bigger cam I can with the
stock exhaust manifold.
Second question : I would go with the stroker kit from "440 source.com", is anybody tried it and is it a good
deal for the price ?
Any comments are welcome
Thanks
Pat
