Make sure ti is an engine problem as suggested ,
you need to take a manifold vacuum reading at Idle in gear if auto & adjust[change] the power valve to 1.5 " lower minimum to work correctly , with low manifold vacuum the power valve opens to enrich the jet circuit , if it is open at idle it will run very poorly & rich , the power valve is located inside the center carb on the rear of th emetering block , generally it is easist to remove the rear & center carb to get at it
