Author Topic: 3 speed tranny and clutch question.  (Read 887 times)
Offline MoparMatt383
  • Member as of March 2004
« on: July 19, 2005 - 07:41:38 AM »
I am getting ready to put my motor/ tranny into the barracuda and I was wondering does the 3 and 23 spline 4 speed trans use the same clutch and pressure plate.  In the auto parts store the computor just specifies 23 spline not 3 or 4 speed.  Also the previous owner said he put a new clutch disk in before I bought it.  How can tell if the clutch and pressure plate has too much wear and if I should buy a new one?
Matt
Too many projects and nothing gets done.
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: 3 speed tranny and clutch question.
« Reply #1 on: July 19, 2005 - 10:17:12 AM »
as far as I know all 23 spline will interchange providing the flywheel is drilled for the diameter of pressure plate 10.5 -11-12 inch etc.
As for the pressure plate the only way I know to tell is to look at the face of the pressure ring ...is it blue? does it have scarring ? small heat cracks? replace it  Flip it over -are the fingers at the same heigth? does the pressure feel equal to each other ? if not -replace
On the disc there usually are rivits that hold the facing to the disc/hub and a new disc will usually have these recessed about 1/8 -3/16 on a new disc --now put it on your trans input shaft and spin it ...is it wobbling ? or does it spin true ?wobbles -replace it is warped
« Reply #2 on: July 21, 2005 - 01:54:51 PM »
Thanks OutLaw I will check it out.  :thumbs:
Matt
