Author Topic: 86 360  (Read 972 times)
Offline MoparMatt383
  • Member as of March 2004
86 360
« on: July 24, 2005 - 05:20:44 PM »
This is a question about the 360 in my ram charger.  It is running rough, still driveable, but just runs rough.  I looked at the plugs and they were a gray/white color.  So I figure they are running lean.  It has a 450 holley vacum secondary carb on it.  I have not done anything yet besides check the plugs.  My question is what direction should I go first.  Timing, Carb, Change the plugs?  What is a good order to go in?  Any thoughts would be greatly appreciated.
Matt
Too many projects and nothing gets done.
Re: 86 360
« Reply #1 on: July 24, 2005 - 10:14:56 PM »
I would adjust the timing , take out some of the vacuum advance with an allen wrench in the vacuum pot & set total timing
then remove the front fuel bowl & up jet 4 sizes you will need new gaskets to do this , the plugs should be tan in color after crusing at a steady speed for 5 miles or so if the plugs are the correct heat range
dodgetkboy78
Re: 86 360
« Reply #2 on: July 25, 2005 - 12:21:25 AM »
I would do plugs wires cap rotor and fuel filter.
then go to tuning. :thumbs:
Re: 86 360
« Reply #3 on: July 25, 2005 - 08:02:09 PM »
Alright sounds like  a good start.  I'll be working on it later in the week and let you know how it goes.  Also I do have a 600 cfm edelbrock laying around.  Do you think that would be better then the 450 holley.
Matt
Re: 86 360
« Reply #4 on: July 25, 2005 - 11:59:39 PM »
the 360 Really needs a 750 CFM carb , but I feel the Holley is a better carb than the Eddy Carb would be
dodgetkboy78
Re: 86 360
« Reply #5 on: July 26, 2005 - 12:14:24 AM »
And I dissagree. :beer: :beer: :wasted:  :thumbs:
Wont hurt to try the eddie though, just my thought. Might like it, I love mine.
Re: 86 360
« Reply #6 on: July 26, 2005 - 03:48:59 PM »
I have em both so I'll give em a try.  I am maily looking for reliablity and towing capcity out of this truck.  I would like to get the best gas milage out of it too.  I know that might be hard with a truck that weighs almost 5000 pounds.   :nopity:  lol
Matt
dodgetkboy78
Re: 86 360
« Reply #7 on: July 26, 2005 - 10:59:35 PM »
my 1 ton dually with 4:10's gets 10-12 with a trailor, and 13-15 with out. It has a 318, with a 600 eddie. :thumbs:
