best rear shocks for 71 challenger?
Author Topic: best rear shocks for 71 challenger?  (Read 3199 times)
chargin
« on: July 24, 2005 - 11:31:10 PM »
what are the best rear shocks for a 71 challenger? i want my car to have a bit of a rake to it.
Re: best rear shocks for 71 challenger?
« Reply #1 on: July 25, 2005 - 12:14:10 AM »
shocks will not affect  ride height , even gas shocks will only mildly change the stance by maybe 1/4 "
 Koni should be the best
chargin
« Reply #2 on: July 25, 2005 - 04:16:29 PM »
so whats the best way to get the right stance?
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: July 25, 2005 - 04:19:18 PM »
Air shocks will give you height, but rides alittle stiff.     :dontknow:
« Reply #4 on: July 25, 2005 - 04:26:46 PM »
  Yeah,
  It's a little stiff alright. The trouble is we all have different tastes as far as stance goes, so the air-shocks are a cheap fix. They get bashed as far as ride goes, but to be honest, not too many of my fillings have shaken loose.  :laughing:
Offline 4Cruizn
  • HEMI FISH
« Reply #5 on: July 25, 2005 - 04:31:47 PM »
I have air shocks in the hardtop and I survive!   :grinyes:
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #6 on: July 25, 2005 - 04:33:25 PM »
We put new Heavy Duty leaf springs on our chally and after we finished the resto, we realized the back was sitting too low and the tires were rubbing on big bumps.  So we turned our QA1 shocks to their stiffest position to see if that would solve the problem...now THAT is a stiff ride! But, it didn't stop the problem.  We finally decided (right before Carlisle) to put the air shocks back on there and that did get us a couple of inches (we only needed about 1 inch).  In the end we figured the air shocks were the cheap fix, but not necessarily the right fix.  So, we ordered super stock springs and will get them put on this week.
Offline 4Cruizn
  • HEMI FISH
« Reply #7 on: July 25, 2005 - 04:37:20 PM »
That sounds good REV . . . curious as to how that works for ya!  Let us know!   :dogpile:
« Reply #8 on: July 25, 2005 - 04:57:29 PM »
Rev,
   What is the difference between "super-stock" and " heavy duty"??? I believe the heavy duty was the 6 leaf springs for big blocks. Mine was about an inch or 2 too low for my taste too.
Offline Rev-It-Up
  • Global Moderator
« Reply #9 on: July 25, 2005 - 05:03:45 PM »
I'm not sure, but Red says "we'll let you know when we put them on!'   :dontknow:
« Reply #10 on: July 25, 2005 - 05:09:32 PM »
   :laughup: :laughup: :laughup:
 I'm glad you'll be the test pilots for this.
Offline Carlwalski
« Reply #11 on: July 25, 2005 - 06:15:30 PM »
For ride height don't you just adjust the leaf springs to suit and correct the parts that are adjacent to match?  :dontknow:
I have Edelbrock IAS Performer shocks and there fantastic.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline inot2old
« Reply #12 on: July 25, 2005 - 06:19:08 PM »
Did air shocks come on 'Cudas?  If so, where was the air valve for them?
'71 Cuda
'70 Charger project
'05 Crossfire Roadster
Offline Killer_Mopar
« Reply #13 on: July 25, 2005 - 06:21:20 PM »
I just bought a set of IAS edelbrocks for my rear. I havnt installed them yet and probably wont for several months, but I have heard good things and I got a good deal on them. As for the ride height, I talked to a spring company (I think it was springs & things) and they said that the best way to raise ride height without sacrificing ride quality is to go with a higher arched spring and they recommended a 2 inch higher arch for my specific needs. They also told me that the superstock springs will get the job done but they are extremely stiff and affect ride quality. Just like a lot of people here, I was running airshocks and I recommend them as the LAST alternative....unless you like hoping around in your seat when you drive on a somewhat bumpy road.
« Reply #14 on: July 25, 2005 - 11:35:07 PM »
air shocks are a band aid approach, the rear crossmember is Not designed to hold the weight of the car & will pound out over time , the real solution is to rearc or install springs that hold the car higher
